주요 콘텐츠로 건너뛰기
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
107 질문 전체 보기
Transferring home button to new digitizer
I just got a new digitizer for a smashed iPad Air, and I noticed that the home button is kind of sunken, and seems to be missing the Hall effect circuitry. Is there a simple fix for this, or do I have to transfer my original home button over? How do I do that? I haven't been able to find any good documentation on how to remove the button and bracket and glue it on. Thanks!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 솔루션
You've been probably supplied an incomplete replacement missing something, maybe the metal pin between button and switch. You can remove and transfer the original with a hot air station, it's kept in place just by biadhesive.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
What kind of adhesive should I use to glue it back down?
의 답변
If done quickly at right temperature with surfaces clean from dust you might be able to just reuse and reglue in place the original without any addition. Otherwise a good quality biadhesive (Tesa just to name one) will be the right choice. Avoid stiff adhesives like cyanoacrylates..they tend to break after a while.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
da stumer 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 50
