Why is my MBP showing 2x4gb instead of 2x8gb ram @ 1600mhz? Help Plz.
Hi everyone,
I have 2 ram sticks of 8gb 1600mhz DDR3 each, installed on my MBP but my MBP is showing the following picture
I swapped the RAM sticks and it is still showing the above.
I checked the RAM sticks in an other computer and it does show 8 GB @ 1600 MHz.
I waived out the fact that the ram slots from the motherboard could be damaged because it does recognize the presence of ram sticks and it does work.
I would appreciate any help on this issue as it seems that I am the only one experiencing such problem...
Thank you !
Update (05/06/2018)
Hi Dan,
Thank you for your reply, much appreciated.
Your reply is structured in two parts:
1 - What the system shows is what the system can support. According to your explanation my system can only support what is shown below, despite the fact that I have 2x8Gb in each slots: Memory Tab of my MBP
2 - Please find below a screen capture of the memory report:
"so going with higher speed RAM on the most part won't gain you anything."
I understand, however I would not mind as long as I could use 2x8gb installed instead of the 2x4gb displayed
Below is the picture of what is installed on my MBP:
Again thank you for your response, problem not solved yet.
Update (05/06/2018)
Hi S W
Thank you for your reply.
Please find below a picture of what is installed on my MBP
And this is the problem that I am facing:
Thank you for your assistance.
좋은 질문 입니까?
댓글 3개
Macs are incredibly picky on brand. What brand are you using? I know I've had problems with Corsair.
S W 의
@arietis_g
Hi, what S W mentioned is true..... list out the RAM manufacturer, model of it, also had you check for any firmware updates for your MAC by software updates ?
Augustine 의
Here's a good reference on what you system needs for RAM: MacBook Pro: How to remove or install memory. And here's the specs for your system: MacBookPro8,1
Dan 의
