주요 콘텐츠로 건너뛰기
The Nerf Maverick is one of the most popular guns in the company's lineup and is beloved for its simplicity and ease of use.
9 질문 전체 보기
Darts stuck up in chamber
On firing, the plunger moves ahead, but the dart does not come out.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
Is it possible to put you finger over the chamber hole behind the revolver? Mine is modded so that the revolver swings out further, so I don't know if you could reach it normally. If you can, check to make sure it blows air out when you fire, or you may have a plunger issue. If it does blow out air out, make sure you are using Nerf brand darts, and that the barrels in the revolver are free of any debris or grime that could be blocking the darts.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Check the teardown guide Nerf N-Strike Maverick Teardown as well and make sure the spring and the plunger line up the way they are supposed to ...Happy hunting..
댓글 달기
it is possible that the darts that you are using are to large for the chamber and or barrel of the gun.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
i got a battery stuck how do i get it out
댓글 달기
귀하의 답변을 추가하세요
Elavarasan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 5,878
