Earpiece sounds distorted, even after replacement
Hi there,
as title says, my iPhone 7 earpiece sounds distorted, so i replaced it, but the problem is still there. Are there more parts included which could be replaced?
Cheers
Jan
좋은 질문 입니까?
Hi there,
Cheers
Jan
좋은 질문 입니까?
Have you tried the other microphones and loudspeaker to see if they appear to work well? The problem may reside in the actual flex cable. You can replace it by following this guide.
However, if this doesn't solve your problem, then the issue could be logic board related.
The iPhone 7 series of devices suffers from issues with the Audio IC and weak traces on the pcb which crack and break. It is a similar design flaw to the iPhone 6 Plus, known as Touch Disease.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 441
댓글 1개
Thanks for the quick response, i'll give that a try...
Cheers
Jan
jmo 의
