Is my Briggs & Stratton 6.75 engine series motor a 4-cycle or 2-cycle
좋은 질문 입니까?
좋은 질문 입니까?
Does it have a metal cover on it that says OHV? if so it is a 4 stroke/cycle.
해당 답변은 도움이 되었습니까?
Hi @vulkus ,
Just for my info.
Is having to add oil separate to the fuel in an engine a good indicator that it is a 4 stroke?
Don't 2 strokes have oil added to the fuel? Just curious.
Cheers
I believe if you need to add oil to the crankcase and it has a dipstick it is a 4 stroke. If you need to add oil to the fuel mix it is a 2 stroke. Unless of course it is like the old motor boat engines that had the separate oil tank.
Thanks very much.
In a mower, a seperate oil fill or dipstick denotes a 4 cycle engine. Straight gas with no more than 10% ethanol is required. Smaller handheld lawn equipment that is also 4cycle requires fuel/oil mix. Its important to read your manual.
24 시간 전: 1
7일 전: 30
30일 전: 130
전체 시간: 4,406
댓글 1개
Is Is my Briggs & Stratton almost series 6.75 a two-stroke or four stroke engine
=== Update (04/10/2021) ===
Is my Briggs & Stratton gold series 6.75 engine a two-stroke or four stroke
Roy Isaiah 의
