1982 1100 maxium won't run out.
1982 maxium 1100 cc starts fine. Idles fine on 1/2 choke. But when throttling up dies right away? Needs to idle will only throtle up when using starter fluid
좋은 질문 입니까?
좋은 질문 입니까?
What type of fuel are you using . Does the bike sit for seasons at a time where it doesn't get to run. When was the last time you had the carbs apart and cleaned . If the bike sits for 5-6 month or longer the ethanol in fuel can cause a green film inside the carb . This film can form obstructions in the jets and close the size jet don to were it will idle but not enough fuel gets through to run the engine up to speed. If this is the situation be careful not to try to run the bike on the choke this can cause a lean burn that can damage the cylinder heads and pistons . Hope this helps
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 32
