주요 콘텐츠로 건너뛰기
Model A1288 / 8, 16, or 32 GB capacity
588 질문 전체 보기
질문 마감됨
After change audio jack the home botton dont work
Good day everybody my name is Jesús i am of Venezuela
i fix ipods and have this case with a client
the client send me an ipod touch when i recived worked OK but the audio jack was damaged no listen good the sound and proceed to install the new part this works perfects and when close everything the home button dont work someone here was fix this troubble? y buy and install other button but the problem insist
any help please make me happy, :D
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
i check and checking see that the contact with metal of frame then work and then the logicboard its good
crazy no?
thanks for your quick answer
GsuServices, is it working again?
의견 추가하세요
답변 1개
More then likely you damaged the logic board while soldering in a new audio jack.
Logic boards are very easily damaged with heat and having not opened one up myself i'm not positive on the schematics or layout of the Ipod Touch 2G.
Check your logic board for cold solder joints and any padding lifted up on the board.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 586
