GPU/CPU working at 50%
Hello,
I have old iMac Intel 27" EMC 2429, under OS X, tried many versions, my CPU is not turbo boosting at any time, it works at 1.6ghz, and my GPU is working at some 30% of speed it should work at.
On the other hand, under windows bootcamp my graphic card is working at 100% but CPU is still not turning turbo boost on and i get flat 1,6ghz.
I don't have screenshots on my home computer to show for but if anyone has any idea what can be the reason behind this it would help me.
p.s. i have noticed GPU flow (not right away) after graphic card replacement, sadly after 3 months of replacement guarantee have passed.
Update (07/26/2018)
Ok @danj it seems we are on right track, it looks to me like they are tore off in my case too, what is my next move? :) do you know what exactly i need to buy to soldier on?
Update (11/12/2018)
screenshots after fix
좋은 질문 입니까?
댓글 2개
Not enough info here to help.
Did you run diagnostics on the system? Also down load this app: TG Pro so you can monitor the systems thermal sensors and fan. Tell us the error from AHT and snap a screenshot of the full main window (you may need to expand it a bit to get all of the sensors visible) and paste it here for us to see. 기존 질문에 이미지 추가하기
You also spoke about replacing the GPU card what card is your system using now?
Dan 의
i get this error in AHT: 4sns/1/c0000008: TAOP--124
i have also purchased replacement sensors some time back, 2 of them and tried replacing it, tried both of them and problem is still there.
I have uploaded screenshot from TG Pro, my fans are going berserker since Macs Fan Control won't start atm...
I have just reinstalled Macs fan control and took snapshot from it's sensor readings.
also i have just uploaded images from cinebench from both mac osx and windows 10 for reference.
ill try to put longer AHT now to do it's magic.
Predrag 의
