주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
758 질문 전체 보기
megsafe T or L type for MacBook Pro 15" A1226?
The battery for my old MacBook Pro 3,1, 15", A1226 does not charge.
I use the 85W L-type charger. Is there a difference between the megsafe T or L type for it?
I only can use it connected with the megsafe, it always lights up green. Profiler says the battery has only about 140 cycles, but wont charge.
I already cleaned the connections etc.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Here's a good reference: Apple Portables: Troubleshooting MagSafe adapters and see if this is your problem: Portables: L-shaped MagSafe power adapter does not charge computer and LED indicator light does not illuminate
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
oh, wow, the article of second link is very interesting, I didnt know that..
I just tried the SMC Firmware but installer says I dont need it, maybe because I'm on 10.6.8 already.
I don't know, but is there a difference between the height of the socket ?
There are two models of the Magsafe 85 Watt, the L- and the T-shape.
It seems that the original L-socket sits a tiny bit deeper in the MacBook dock?
Therefore the pins make better contact than the L-form?
http://fs5.directupload.net/images/18051...
The connector interface to the socket is the same. As long as you have the same wattage charger they are compatible.
댓글 달기
The Apple info page shows that only the T-shape is right for the late 2007 A1226 model I guess..
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
The listing is what the system came with only! Both can be used.
ok, thanks..it is a bit misleading because the L-type is listed for the 2010 and up models..
댓글 달기
귀하의 답변을 추가하세요
Jamba 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 478
