주요 콘텐츠로 건너뛰기
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
86 질문 전체 보기
My ipad screen getting wrong.
Can anyone explain what wrong with my screen? I tend to order a new screen and replace by myself but I'm not sure what the cause is? I’ll appreciate if anyone had the same problem with me and share your experiences for a precisely diagnostic! Thanks you so much!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I would tend to suspect a damaged screen. However as Nicky suggested, you should try to do a hard reset (Home & Power Button for 10 secs) of the device to see if that helps. If it doesn't then the next step is to try a replacement screen. Unfortunately, iPad Air 2 replacement screens are very expensive right now. You could bring it into a shop and ask them to see if the screen is the issue. They may charge you a diagnostic fee but that is less expensive than ordering a screen just to find out.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
My Ipad Air 2 had the same problem. It would return to normal after a day of non use. It slowly got worse until the screen would freeze and go black. Given that new info, do you still suspect a bad screen, or is it more likely the logic board? Thanks in advance.
댓글 달기
Did you try take a backup and reset the ipad ? i highly doubt this is a screen problem, more like a software problem, also it could be a defect homebutton in the meaning that it will work but if you click it it wil stay clicked giving you everything to see ( siri and so on )
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Khoi Nguyen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 1,007
