주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
267 질문 전체 보기
iPad air power issue
My iPad Air (A1474) has a power issue - it's showing no signs of life. The only clue I have as to the root of the problem is from my usb amp meter; Powered from a 1A power supply, I see the charging current rise very briefly (anywhere, upto 1 amp) before falling back to zero. This cylcle of current rise and fall continues no matter how long it's left charging. Different power sources produce the same results.
Having followed the steps in the Ifixit 'Ipad Troubleshooting' guide, I can only assume that the issue is either battery or logic board related (since it isn't recognized by my PC, i'm guessing a bad display would not be the issue, but as i'm a novice in Apple architecture, I could be wrong). Which is why I'm looking for an expert opinion the matter: What is the likely culprit?
Thanks in advance.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
The first thing to isolate is the battery. It's the easiest component to replace and the most likely to fail. Start by removing the old battery and measuring it's voltage with a multimeter. If the voltage is above 3.2V, the iPad should boot and failure to do so would indicate a logic board issue.
If you are seeing less than 3V, the battery is either fully discharged or dead. If a new battery doesn't solve the issue, then your problem is with the logic board.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
귀하의 답변을 추가하십시오
Jand 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 68
