주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
Power button, earphone jack, vibrate toggle switch will not work?
I have no memory of anything that would cause the following errors, but as of yesterday:
The on/off button does not work - I cannot hardkey a restart or even put the phone on sleep
The vibrate toggle switch does not work
The headphone jack does not work.
I have already restored the iPhone and made sure I installed all updates.
Is my only option to replace these three items? If so, I think I'd be better off buying a new one.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
shop around for the flex, they aren't that expensive, but the repair is time consuming and fiddly. just take it slow, read the guide several times and then attempt it. make sure to take care to move the gold antenna out of the way of bezel before removing the motherboard. Try Brad's suggestion first
댓글 달기
답변 2개
선택된 답변
These functions are all connected by a single flex cable, Cable #5. Making sure the iPhone 3gs is OFF before starting. What I would do is carefully open the iPhone with a suction cup, being very careful not to damage the screen Flex Cables 1,2,3, especially #3 and its connector. Once open I would make sure Flex Cable #5 is seated correctly to the Logic Board. I would pop #5 off carefully and then snap it back down carefully into place. Then carefully put the iPhone back together.
Good luck,
Brad
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
and where is #5? Is it labeled just like the others??
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sarah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,975
