주요 콘텐츠로 건너뛰기
최초 iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s, iPhone 6s Plus, iPhone 7, iPhone 7 Plus, iPhone 8, iPhone 8 Plus, iPhone X, iPhone XS, 그리고 iPhone XS Max에 대한 작업 및 교체 안내서를 작성하여 주십시오.
33172 질문 전체 보기
Where is the phone's backlight?
Hi,
After water damage and drying it out, iPhone finally came on but the tochscreen is not working at all.. can´t slide the bar to get into the phone, can´t turn it off... etc... also it does not have a backlight... i can see the phone is on but very dimmed..sound, it rings, but can´t answer calls and no backlight.
I am about to purchase the parts to fix this but would like to know if i just need the front glass + digitizer alone or should i also buy the lcd screen to fix the entire problem...
Thanks a lot in advance...
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
3개의 답변
가장 유용한 답변
The backlight is actually a small CFL bulb integrated into the bottem and top of the LCD panel, you would need to replace the entire LCD panel to fix it, as well as the digitalizer that is broken in your phone, depending on whice iPhone you have, this is either an easy fix, or an incredibly hard one, you could also check that the display cable is seated fully into it's socket, and the same for the digitalizer cable.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
how do you turn on the flash light
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Phone the backlight problem
해당 답변은 도움이 되었습니까?
점수 0
댓글:
No on the backlight phone please help the problem
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Coto 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 5,667
