Broken lid lock on washer
I broke lid lock on my Maytag washer. If i use screwdriver down lid lock hole and push in button, it will wash but wont rinse or spin put. Can i disconnect the lid lock and still use my washer???
좋은 질문 입니까?
좋은 질문 입니까?
I believe disconnecting the switch will result in no action. The switch wires have to be connected together to allow the washer to run if I am not mistaken. Keep people with long hair (also dangling jewelry and loose clothing articles) away from the washer when it is running if you make this change to it!!!!!! Those switches are readily available on the internet for very cheap so I think I would go ahead and fix it correctly.
해당 답변은 도움이 되었습니까?
The switches on a Maytag Bravo are expensive. They are over $115.00 Canadian with shipping. Not sure where they are very cheap.
I do not recommend this but here’s how to bypass the switch till you get the new one installed:
해당 답변은 도움이 되었습니까?
Will my Maytag washer still wash and rinse and spin without the lock button, my lock button is broken off ..
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 15
30일 전: 53
전체 시간: 16,059
