주요 콘텐츠로 건너뛰기
LG Aristo MS21O android phone repair and troubleshooting.
42 질문 전체 보기
Why can't someone hear me but I can hear them
I can hear someone talking to me but they can't hear me
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개:
my microphone for Google and talk to text works but the speakerphone microphone does not work
댓글 달기
답변 3개
It could be as simple as a plugged mic port. If you know where the mic port is located try cleaning it out with the brissels of a brush and then blowing it out. If that does not work try resetting the phone. And then if that doesn't work it would be a hardware problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If this occurs with more than one person, you most likely have an issue with your device's microphone. If this only happens with one person however, they probably have an issue with their speaker. Try speaking while the phone is on speaker, and check to see if anything is obstructing the bottom of the device. Good luck, let me know if you need more help!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I'm having a similar problem except incoming calls can only hear me on speaker
댓글 달기
Is Sprint your cell phone provider? Sprint sometimes has the problem you have described. That's one of the reasons I switched from Sprint to Verizon.
Or maybe the person you are talking to has Sprint. If all such people have Sprint, or if you have Sprint, I suspect that Sprint is the source of the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Lynn Spencer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 3,355
