주요 콘텐츠로 건너뛰기
MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
4189 질문 전체 보기
Screen is covered with lines with large black spots and border
My mac screen is almost completely covered with vertical lines white screen and black spots with black borders. It started off with vertical lines, few days later a large black spot showed up then I noticed the top of the screen was turning black almost like it was leaking black ink. If I take a screen shot the ugly screen doesn't show up in the image. On top of that my computer will not work unless its plugged in. What do I do?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글:
I was away from my chrome book for a few minutes. And when I came back my screen was covered in lines and big black lines. It looks like the computer is cracked. But when I turn it off and feel it, there is nothing. My chrome book won't even charge. I'm not sure what to do.
의 답변
My sisters is just like that and i have no idea what to do either please tell mme if you figured it out
의 답변
I dropped my laptop and now the ink is rising and there are lines on it what do I do
의 답변
의견 추가하세요
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
3개의 답변
선택된 해법
I am 95% certain you need to replace the LCD based on your description. However lets do a few things to rule out all possibility of it being any thing else. Move the upper part of the laptop that holds the lcd backwards and forwards from the hinge, while observing the display. If things get better or worse by doing that it could be the video data cable or a bad connection to that cable. Hook up an external monitor up if the picture is good on an external monitor. Then it is either the LCD or the video data cable. If the picture is similar on the external monitor the it is most likely either failing video memory or GPU. Please let us know more after you have tried these test and we will help you get the part that needs replaced and provide a guide to replace it.
해당 답변은 도움이 되었습니까?
점수 7
댓글:
+ sounds good to me:-)
의 답변
I just replace the LCD and I'm getting the same vertical gray lines! I can move one line left to right with my finger on the pad.
의 답변
의견 추가하세요
Sounds like you need to replace your LCD. Go under the Apple icon in the upper left hand corner to "about this Mac", more info, >Hardware > Graphics/Displays. Get the information on your screen.
Also please give the last three letters of your serial number so we know exactly which machine you have. (located in the battery compartment). This will allow directing toward the correct guide.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
What about this!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Erinn 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 46
지난 30일: 242
전체 시간: 28,852
