주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
Replaced headphone jack assembly but mute and volume dont work?
I replaced the headphone jack assembly in my 3gs because the power button stopped working after installing it and putting the board back in i plugged in just the lcd to see if the power button worked and it did but then i realized the mute and volume buttons dont is this because the other components arent plugged in to the board yet or did i install it wrong?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
you haven't connected them to the buttons on the rear case and they don't work? or they are connected to the buttons and don't work? they should work if you press on the plastic toggle on vibrate or the little discs on the volume
Ok now after tinkering with it the mute button works now but the volume button still doesnt ????
댓글 달기
답변 3개
선택된 답변
Sounds like you have connection problems.
Rub all copper connectors with Methylated Spirit on a NON lint cloth to clear obstructions.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Check if its well connected at first.. but if it is and yet it doesnt works you might change the part again.. :/
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
make sure you properly connected conector 5 that is what drives the mute and volume buttons then make sure your past the lock screen and they sould work. One last thig is in "settings" select sounds and make sure the "change with buttons" is turned on
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jared 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,061
