주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
Blank LCD after replacement digitizer, front frame and lcd separetely
We have bought LCD, digitizer and the front frame separetely to fix the broken glass and for easier replacement in the future.
everything work fine before the replacement. durring the replacement all seem to me in place but when i turn it on. The back light work but nothing on the LCD. after a while i can unlock it and itunes detect it but no LCD.
- I have verify the connectors 4 times.
- hard reset change nothing.
- restore with iTunes change nothing.
now i don't know if it is the LCD, the logic board or my assembly ?
P.S. I have lost de top rubber of the logic board.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 13개
I have the same problem, Do any one have a solution to this?
I am having the same problem but I had the fully assembled front replaced and all I'm getting is a black screen. LCD lights up in the back digitizer works fine...I can unlock it detect it in iTunes. Please help?
I have the same problem... this is crazy :( someone please help!
I will send it to another compagnie and i will comment you as soon i can.
Im having the same problem. PLEASE, somebody find an answer to this.
댓글 8개 더보기
댓글 달기
답변 8개
가장 유용한 답변
We had this problem a couple of times too after disconnecting the LCD panel, The solution is simple:
Just hold the Home & Power buttons together at the same time until the Apple logo appears and the the problem will be solved..
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Sorry guy's, Correction:
This solution is solid proof, But i forgot to mention that it works every time but with iPads, I haven't tried it with an iPhone, Actually i never had this problem with an iPhone. as i have a repair shop and i deal with iPads and iPhone everyday..
댓글 달기
I had the same problem. Check to see if a ribbon cable from the lcd and digitizer tore.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
my ribbon seem to me good.
댓글 달기
The hard reset isnt working for any1, any other ideas?
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
anyone tried to see if their old one works? If it does then your problem is the new solo LCD!
well in my case i was just fixing the power button! i think it must be the LCD ribbon!
try disconnecting and reconnecting the cables..it may not be on fully
댓글 달기
yeh iv taking it apart good few times, everything in right and tight, looks like ill be getting it checked in the morning, iv being fixing my iphone from the very first one and normally have an idea whats up but this is very strange, i would say its the ribbin doh!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had the same problem. Check both ribbon cables for the screen. They should be the exact same length after installing it through the metal housing. When I had the problem, the cause was a torn ribbon cable. Check there first.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Well it seems that my problem was a torn ribbon cable too. I guess that they are extremely delicate and tore very easy.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I'm having the same problem, I've checked my cables and they're not torn. D;
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
take out battery connector for 5 minutes and then connect it again the lovely apple sign appears on the screen
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
if it works and it will work please give feedback
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 13,274
