주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
1506 질문 전체 보기
LCD malfunctioning with a fully working touch screen glass screen
I recently dropped my iPhone 7 on the floor with the back facing the floor. When I lifted it up its shape seemed to be fully intact , it`s LCD was malfunctioning ( It seems as if the upper part of the screen is working but reflecting the lower part of the screen at the same time; there is a crack beneath the glass screen and not on the screen that can be seen when the phone gets lit up) and its glass screen was fully intact. I was able to use all the function on the phone including touch screen, camera and listening to music .
After a few inspections on my phone, I realised it is very slightly bent ( almost impossible to see). The phone`s LCD sometimes works ( the image can be perfectly seen but there are transparent lines going throw it and the crack still stays) and soemtimes doesn`t ( the upper corner of the screen has coloured lines going throw it and the weird reflection can be seen again).
What happened? How much does it cost to rapair? Shpoul I repair the phone?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 수리 키트
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
답변 1개
선택된 해법
Sounds like you need a screen replacement. Look over the guide and see if it’s something you think you can do yourself, otherwise you can take it to a shop and they will fix it up for you.
iPhone 7 LCD and Digitizer Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글:
how much would it cost for someone professional to replace it
Alexander,
My store charges $99 USD to replace the screen on an iPhone 7, but it is going to vary greatly depending on where you are and the stores in your area.
의견 추가하세요
귀하의 답변을 추가하십시오
Alexander Alexandrov 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 33
