iPhone 6p board damage when cleaning u1401
Hi guys
this is pins under u1401... this scar is little deeper
i have photos attached . I need to know how can i get back those pins that damaged
좋은 질문 입니까?
Hi guys
좋은 질문 입니까?
The picture is not very clear and it's a little difficult to get the orientation right so I'll give you a more generalized answer. Perhaps is your digital microscope allows you to export pictures, then you can post it here.
When pads get ripped, you essentially have to run a jumper from where it should connect directly to underneath the IC in question. You have to use very thin wire as you can't create a situation where it raises the IC causing other pads to not connect properly. Several vendors sell 0.02mm enamelled wire. You will need to use UV-Curable mask to hold the jumpers in place.
Here's are a few examples:
So use the schematic and Pads viewer to figure what connects where and run the jumpers.
해당 답변은 도움이 되었습니까?
Yes i understand its very hard but i will try with wire and uv mask
same happened to 5s nand pins
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 116
댓글 5개
looks like you need to run jumpers, if possible
daniel 의
how ... an example?
tatlisub 의
have you got zxw
daniel 의
Yes i have pabs pcb viewer. I can see pair or net for those pins but what can be done?
tatlisub 의
tatlisub 의
