주요 콘텐츠로 건너뛰기
Released August 2014. A 16.0 MP point-and-shoot camera with a 3.0 inch LCD monitor.
7 질문 전체 보기
How to return a part of a graphic object?
I was editing bulk graphics in AutoCAD when a crash occurred. I just unloaded my photo-work done the day before, into the program for further processing and overlay, but after a failure in AutoCAD, I now do not see a few photos. This is impossible, because I didn’t delete them accurately, they combed it out on their own.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Can you view the file here, using Autodesk's online file viewer? If not, then it's probably corrupt.
• Go into the same folder as the DWG file, and look for the same named file, but with a .BAK file extension (You need to have file extension TURNED ON).
• This is the last save before your last save.
• Then rename that file from BAK to DWG and try that one.
• If that doesn't work, then go into your %temp% folder (in the address bar of Windows Explorer, type in %TEMP% and press enter).
• Sort by date and look for a file name similar to your original file, but with a .SV$ file extension.
• Rename that to .DWG and try it.
• This is your last Autosave file (it may not exist)
• If that does not work, look for the same named file in the %TEMP% folder with a .BAK file extension.
• This will be your next to last autosave file. It may not exist either.
• If it does, rename dwg file and try to open it.
Source that tell you how to repair dwg file:
https://knowledge.autodesk.com/support/a...
http://www.thesourcecad.com/recover-dama...
http://www.dbf.repair/
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
MillieDean 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 55
