주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
모델 A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 또는 2.8 GHz Core i7 프로세서
399 질문 전체 보기
No output on display
Hi all,
I have an iMac (mid 2011 21.5) where the screen will no longer come on at all. The HDD had failed, I replaced it and put it back together but now I get no output. I cannot check if an external display would work because I don't think the iMac's display anything till booted on an external display (cant boot the Mac cause the HDD is new with no OS).
The connectors for the screen look to be seated right and I have tried to re-seat them also.
All 4 diagnostic LEDs light up on the Logic board but I still get no output on the screen.
Any advice would be appreciated.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Hi,
Thanks for this, all connections are sound in place and all look intact.
The Mac boots into Internet Recovery but only when the internal display is unplugged, is this normal? Or could something in the screen be causing the Mac not to boot?
Thanks.
It could be that the backlight on the display died. Try shining a light onto the display when it is turned on and see if you see a startup screen or icons.
Hi,
Thanks all! From what I can see/ can’t see, there is no image at all on the screen.
의견 추가하세요
답변 2개
Try a pram reset . if that brings nothing try connecting an external display and try and enter into network recovery. When trying this you should see something on the external display,
https://support.apple.com/en-gb/ht204063 -PRAM REST
https://support.apple.com/en-gb/HT204904... RECOVERY
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Please make sure this cable is well positioned and connected properly.
(please check the link)
iMac Intel 21.5" EMC 2428 Hard Drive Replacement
Otherwise, you should check other wirings aren't broken.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Dan Poulter 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 62
