주요 콘텐츠로 건너뛰기
The device Samsung NP700Z5AH was released on September 24th, 2012. It can be identified using its model number: NP700Z5AH. Its color is aluminum silver.
2 질문 전체 보기
질문 마감됨
It's difficult for me to fix it..
During my work with MS PowerPoint something strange happened. It's difficult for me to fix it, and I turned to you for help. Today one of my documents was not opened for some reason. What can I try to do with this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Hi @tiamiles
You mentioned only one of the documents, how about other documents? and if you copied the affected document to another pc, does it opens?
what microsoft office are you using?
댓글 달기
답변 2개
선택된 답변
Try restarting your laptop
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The steps, which are mainly required for this solution repair pptx file:
1. Open MS PowerPoint program. Click on Office button (on top of the left side).
2. A window will be appearing. Now select corrupt PowerPoint file from the system directory.
3. Click on the arrow of Open button. A list will be scrolled down.
4. From the list, click on Open and Repair. After some seconds, the file will be repaired and opened.
Another method, if nothing helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 78
