주요 콘텐츠로 건너뛰기
Fourth generation Honda Civic
33 질문 전체 보기
car turns on but when given gas dies. engine light on.
Recently got my car fixed by replacing the ignition switch. in the last couple of weeks i have also replaced spark plugs, wires, rotor cap and rotor along with the Fuel filter. it has been driving and idling pretty ruff and as of today driving it home i was giving it gas to where it felt like it had no power till i finally came to the point of my gas pedal all the way to the ground with the check engine light ON it didn't t wanting to go anywhere at this point. i was lucky enough the side road opened up to where i wasn't stuck in the middle of the road. i ended up getting it towed home . car starts up but wants to die.
91 civic wagon , Auto
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Have the timing checked . Its probably the timing belt has stretched or slipped . Honda timing belts should be replaced every 60,000 to 100,000 miles. depending on how you drive . Hope this helps
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
sandyperaza 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 117
