주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
The Ford Expedition is a full-size SUV assembled by the American automaker Ford Motor Company. Introduced as the four-door successor of the two-door Ford Bronco, the Expedition has remained in production since the 1997 model year; it is currently in its third model generation.
61 질문 전체 보기
What is the most likely cost for Cylinder 4 misfire code P0304?
The vehicle has a noticeable shake when idle, and hesitates when reaching speeds of 55-60 mph. What is the most likely cause?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
답변 2개
가장 유용한 답변
'''++Recardo Grady++'''  Code 0304 is a continuous misfire code for cylinder #4. #4 is the rear cyl. on the pass. side. Causes can be a bad coil or a loss of fuel in that cyl. Depending on what size engine your vehicle has, one has the coil-on-plug system while the other does not. On a 5.4L which has the coil-on-plug #4 coil is prone to failure due to water in the plug well from the heater hose that runs above it. Of course it could also be a clogged injector etc. Start with the coil…..The cost for the repair will depend on what you find during your trouble shooting.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
Hi Recardo,
Based on what you've explained, to me it sounds like you may have a worn-out spark plug, ignition wires, or a vacuum leak somewhere in your vehicle. I would inspect cylinder #4's spark plug and wiring for any physical damage. Try a replacement spark plug to see if that fixes the problem. If not, I would recommend taking it to your mechanic for further investigation.
Best of Luck,
Drew.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Recardo Grady 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 18
30일 전: 88
전체 시간: 3,611
