주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
Digital calculators with varieties of features useful for students and professionals. These devices are good for calculus, trigonometry, engineering, financial, and other types of problems.
250 질문 전체 보기
How do I take off the foil cover of a TI-84 plus calculator?
I am a junior in high school and I have a TI-84 Plus calculator, the screen of which has a few horizontal lines of dead pixels (the bag it was in was damp), but everything else works. I am trying to take the calculator apart in order to fix this problem, but I am unable to take off the foil cover. I have seen and read that there are supposed to be two screws holding the foil cover in place but I don't see any visible screws. Also, in other calculators of this same exact model the foil cover extends further, but in mine almost half of the circuit board is exposed.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 1개
선택된 해법
Hi @yellowtimewhale
It seems that on this revision, they had melted the plastic to hold the foil.
From my experience, use an exact o knife / penknife (use with caution) to carefully scrap the plastic out.
The Foil shield bottom should be a double sided tape adhesive which is used to hold and stick to the calculator mainboard.
해당 답변은 도움이 되었습니까?
점수 6
댓글:
Thank you. Yep I thought that something was different about this calculator.
의견 추가하세요
귀하의 답변을 추가하십시오
HRFowler 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 75
