Shows unknown IMEI and i-tuns will not restore
3gs shows unknown IMEI and ICCID
좋은 질문 입니까?
This is a very bad warning. The problem could be many things, water damage, hardware failure. But lets go with something you can try. A DFU mode restore. Open iTunes on computer. Connect iPhone to computer. First push Home button and then push Power button, count 8 seconds and let go of Power button, keep holding Home button until iTunes says it has detected iPhone in Recovery Mode, then let go of Home button (usually about 15-25 sec). The iPhone screen should be blank (black), if an image is on screen you are not in DFU mode. If in DFU mode then click to let iTunes restore your iPhone. If not in DFU mode, try to enter DFU mode again. Even experienced users can have a bit of trouble entering DFU mode, keep at it until you get it into DFU, iTunes will tell you when (Recovery Mode window), as long as screen is blank (black). Good luck. Brad
해당 답변은 도움이 되었습니까?
Most times this will end in error 23... Cannot restore. The problem ic requires soldering skills and tools only professional repairers have. Let us know what you get with dfu and how you want to proceed
Most of the time that error is because the battery is not giving juice to the boot loader chip, try first to change the battery since the boot loader only will work from the battery power even so if the phone is directly connected to the outlet.
해당 답변은 도움이 되었습니까?
+have seen bad battery give these signs many times.
Imei:013268003346713 iccid: unknown
chang the battery and see if ur battery is deamag it will work.
i agree with u. but some cease is different battery is good imei iccd is unknown.any solution ?
해당 답변은 도움이 되었습니까?
iphone imei unknown iccid unknown
해당 답변은 도움이 되었습니까?
8997103113101650188
iPhone iemi unknown iccid unknown
I used to have the same problem no imei no iccid, after i change battery everything start working.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 7,660
