주요 콘텐츠로 건너뛰기
점프 스타터 및 자동차 충전기를 포함한 승용차 및 트럭 액세서리 수리 및 지원.
309 질문 전체 보기
Does it matter which way I mount my winch?
I recently obtained a winch for my ATV. I mounted it with the cable winding and unwinding from the top of the spool, not the bottom. After mounting it, I found that the cable is supposed to wind and unwind from the bottom of the spool, not the top of the spool.
Does it matter which way it is mounted?
https://www.harborfreight.com/2500-lb-at...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Your controls will be reversed. Instead of winding up it will be unwinding.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks for your answer. I'll try it later, when I have all of the wires connected.
You were right, Mr. Mayer! The controls are reversed; otherwise, the winch works perfectly!
The winch is actually mounted on the back of my riding lawn mower. Sometimes I get stuck in the mud when I am cutting the grass. It has been a real hassle to get unstuck, so I asked my wife to get me a winch for Father's Day. Last night I successfully pulled the lawn mower using the winch, so I look forward to not getting stuck anymore!
댓글 달기
귀하의 답변을 추가하세요
MrJimPhelps 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 813
