주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 질문 전체 보기
MacOS will not start
I have a new SSD installed and working in this computer. But MacOS wont’t show the installation screen because its grayed out.
I have tried to zap the PRAM, replace the backup battery, tried to boot from USB and Internet recovery, removed the RAM... everything.
Anyone got a clue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The drive needs to be formatted with the correct format. Using your external drive to boot up with run Disk Utility and format the drive with GUID and a Journaled volume. Then you can install the OS.
해당 답변은 도움이 되었습니까?
점수 2
댓글 6개:
I am a little bit more pro than that (thanks for the answer though). The problem is that the computer do not continue to disk utility.
OK, then lets get more details here as clearly something is a mis. Who's SSD (make & model) are you using and which port are you connecting to HD, optical drive or the spare and lastly, what is your MacOS.
Also can you post a screen shot of the Disk Utility screen 기존 질문에 이미지 추가하기
@danj Is an Apple system update going to try to mess with the GUID format on this SSD?
@mayer - Yes! High Sierra will automagically update the drives partition from GUID/Journaled to GUID/APFS! This can be an issue if the person is trying to install an older OS onto the drive after its been setup with High Sierra.
If you are talking about service updates (not upgrading) they won't change anything.
There is a new TR200 drive from Toshiba, the original Apple SSD have the same problem, gray screen when booting.
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
peter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 83
