The Volvo XC90 is a mid-size luxury crossover SUV manufactured by Volvo since 2002 and now is in its second generation.
1 질문 전체 보기
Volvo XC90 2.5T Will Not Crank, Starter, Relay, Fuses All Good?
All of a sudden with no warning stopped and would not crank, no immobilizer activated, just won't crank, had to have towed home, checked starter, jumping pin 87 to 30 cranked starter, so it is not starter, swapped starter relay, checked all fuses with meter, pulled halo to check connections, pulled apart ignition and sprayed electronic cleaner on contacts and connections, nothing has helped. Any suggestions on how to resolve this mystery.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
2개의 답변
Greetings everyone,
I hope that this issue is been solved by now. However, for those of you following this thread, I would suggest to check the battery first. Are all the components getting electricity, can you hear the fuel pump running. Just asking, by any chance did you get new key fobs?
Best of luck to you all!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Sad to say, it turned out to be key transceiver which set immobilizer to not crank. Had to have XC90 towed to dealer since it has to be programmed, they didn’t get to even bringing vehicle into service for 5 weeks, then the bad news, they had no key in stock, had to order from Sweden which killed another week, but here is the worst part, $550. for a flipping key and programming. Last Volvo I will ever own. By the way, I replaced starter, starter relay, new battery even though it was only a year old, new receiver halo, ignition switch, so everything but the most expensive issue, the key. Lesson learned, with Volvo’s it is always the most expensive part. lol
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
M Sullivan 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 119
전체 시간: 552
