주요 콘텐츠로 건너뛰기
1.83, 2 또는 2.16 GHz Core Duo 프로세서
281 질문 전체 보기
Shorted out inverter cable...test connector vs logic board damage?
MacBook Pro 15" Core 2 Duo Model A1150
Put the wrong back panel screw (fit but too long) during reassembly and shorted out the inverter cable. Smelt smoke upon startup, shut it down, removed screw, restarted. Now I have a very dim display and a stinky logic board (at respective connectors). I know I should replace the inverter cable, then inverter board, but if those fail, I've wasted >$75 and then have to move on to testing logic board connectors... can I try this step 1st? I have a bad feeling I've fried the connector, meaning I'm screwed. How do I test the connectors/logic board? Voltmeter at pins?
thanks a bunch!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
This is the cable you most likely need: MacBook (Core Duo/Core 2 Duo) Inverter Cable
To be sure please give us the last three letters of your serial number. It's $18.95
MacBook (Core Duo/Core 2 Duo) Inverter Cable 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Hi Jeff, Did you get your issue fixed? I have a similar problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jeff Bennett 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,853
