주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2687 질문 전체 보기
My iPhone starts rebooting after 20-30 minutes or use after restoring.
My iPhone starts rebooting after 20-30 minutes or use after restoring its IOS every time.
Its battery health is 91%
I ordered a set of Logic Board and Touch ID for my iPhone 6s from China (AliExpress)
It worked for about 25-26 days perfectly without any problem.
After these days it started rebooting and getting stuck on Apple Logo.
To fix this I even tried to restore its IOS (11.4).
After restoration iPhone started and worked for 2 hours initially.
After that same problem again.
It is not even jailbroken.
1 day I was trying to solve this issue and I got an error while restoring it (Error Code 2009 on PC and 4014 on my MacBook Pro) both errors were on iTunes.
after that I tried to restore it using 3U Tools.
It successfully restored and worked for 2 days but after that same problem started of rebooting and getting stuck on Apple Logo.
1 day I opened my iPhone and checked the Logic Board and I found it was Water Damaged from Circuit area where Audio IC, 338S00120 Power Management IC, etc are present
I Cleaned it Properly using Alcohol and give some it some heat at that particular Circuit using a heat gun.
And after that I tried to restore my iPhone and it Success Fully restored and worked perfectly for 4 days now.
But again now it is showing same problem and this time it shows error 9 once on my MacBook Pro but after that I used 3U Tools and restored it and again tried to restore it using iTunes using my MacBook Pro and this time no error while restoring but that old rebooting and Apple Logo Stuck problem is still here.
I am very much frustrated now of this.
Can anyone please help me to solve this problem permanently.
Thank You!
Best Regards!
Vaibhav Dogra
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
If I understand correctly, both the original and the replacement logic board have the same reboot issue?
If that is the case, then something other than the logic board is causing this issue. If you have already tried a new battery, then try disconnecting only one peripheral at a time, like the cameras, sensors, lightning port. If the phone starts working properly with one component removed, then you will have found the culprit.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
No Sir,
Its original logic board is iCloud locked, there is no other problem in that logic board!
댓글 달기
가장 유용한 답변
Have you tried another battery? It could be someone as simple as that.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Yes I Tried a New Original Battery.
but still it is not working!!!
Please give me any other suggestions!
Thank You!
댓글 달기
Hello,
I would say you have to try it in a different housing, even with a different home button, to make sure nothing is causing this issue and it is indeed a board level failure.
In which case you will have to have it replaced from the seller, if that is an option.
Otherwise, a micro-soldering technician might be able to repair it for you. Occasional boot-looping is tricky but I have successfully diagnosed and repaired a few and have a pretty good idea what may be causing this, if it is indeed at board level - just saying it can be fixed but is definitely not a DIY repair, as it may require something like Codec chip re-balling or replacement.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank You Sir,
Firstly I will try to return it to the seller and get a new one!
It it is not possible then I will surely get it to a micro-soldering technician!
댓글 달기
귀하의 답변을 추가하세요
vaibhav_dogra 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 97
