이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
Can you give more details on your issue? I recently had a problem with my left Joy-Con, which would "drift", ie. would move upwards by its own and would not return/stay in its default, central position when untouched. Is this the issue you are experiencing?
If this isn’t a hardware problem. Then going to settings scrolling down to controllers and sensors. Then clicking on calibrate control stick select the stick you want to calibrate. And click y to go back to default settings. that should fix the problem
Louis 의
Chase 의
