주요 콘텐츠로 건너뛰기
다양한 TV 브랜드 및 스타일 안내서 및 지원.
9023 질문 전체 보기
Panasonic 32” LCD TV
The right side of the screen is a thick black bar - LCD may be going, can it be fixed or should I just buy a new tv?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Model number please.
@moe2059 give us your TV's complete model number. What have you checked and did this just start?
댓글 달기
답변 2개
가장 유용한 답변
@moe2059 This can be caused by bad cables or a bad T-con board as well. Depending on your TV’s model number you want to start by checking the ribbon cables going from your T-con board to your panel. Make sure there are no small tears etc. Check that they are inserted straight into the connector and that the connector makes proper contact. Furthermore apply some gentle pressure on the TAB's of teh panel and see if the image changes.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
This can be a panel problem, a connection issue with the cable, or even a backlight problem. If you feel confident in opening the TV, open it up and re-seat the cable(s) going to the panel (both ends).
Update this with the results.
Dan
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mohamed 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 49
