My MacBook will not reboot.
The chime sound is made and it will load to a blue screen but nothing else will happen.
좋은 질문 입니까?
좋은 질문 입니까?
Hi! You might want to take a look at my answer to this question:
해당 답변은 도움이 되었습니까?
If it progresss past the blue screen run Applications->Utility->Disk Utility->Disk First Aid tab: repair disk and repair permissions.
If safe boot fails and you have access to another Mac Target boot (T key) and connect to the other machine with a Firewire or USB cable. Run the same application from the other Mac
Reboo and see what happens.
If this is acceptable please remember to mark it.
Good Luck,
N.
해당 답변은 도움이 되었습니까?
Sounds like your RAM isn't in, open it up, and check that it's in.
해당 답변은 도움이 되었습니까?
If the RAM isn't in, it would more likely beep than chime. It sounds like the hard drive is either not bootable for some reason, or dead. A blank screen after a chime generally means that the computer is looking for a bootable volume but failing to find one.
No, a hard drive failure will bring up the same screen a computer looking for a bootable volume- the question mark screen.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,755
