주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Brother IntelliFax-2840은 가정이나 사무실에서 사용하기 위해 설계된 레이저 프린터 겸 팩스 기기입니다.
My fax machine is in sleep mode. how to get rid of?
Because it's in sleep mode I can not send fax. How do I get rid of this so I can start faxing.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Here is the user guide for your fax machine:
http://download.brother.com/welcome/doc0...
In chapter 1, page 4 and 5, it tells how to set the sleep timer, that is, how long the machine is idle before it will go into Sleep mode.
Press Menu / 1 / 4 / 2. You can then enter the length of time the machine is idle before going into Sleep mode. You can probably put zero to make it never enter Sleep mode. If it won't allow that, then put the highest number you can (e.g. 999999999). But if you do that, it will eventually go into Sleep mode, so "never" would be a better option than "999999999".
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Here is the Software User's Guide for your fax machine:
This guide will tell you how you can use your fax machine as a printer and scanner for your computer. It is a laser fax machine, so you will have a laser printer. And it has an ADF (automatic document feeder), so you will have a nice scanner for scan jobs that are on regular size paper.
댓글 달기
It is in sleep mode I cannot send my fax how can I get it out of sleep mode
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
It in sleep mode
It is in sleep mode cannot fax my paper
댓글 달기
답변을 추가하세요
wpark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 36
전체 시간: 10,411
