주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
658 질문 전체 보기
Earpiece Not Working After Screen Replacement
This is probably the THIRD iPhone 8 or 8+ that has had this issue. Even though we were careful to remove the camera flex cable and the tape with it, and transfer it to the new LCD/Digitizer assembly, the earpiece REFUSES to work. The camera works just fine. I need assistance and answers. I have cleaned the contacts with alcohol. I have installed Kapton tape. I have switched out the piece with a new flex cable and new ear piece speaker. Yet, I know it worked BEFORE we took the phone apart. Suggestions on how to use the ORIGINAL flex cable?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 9
댓글 달기
답변 1개
You want to make sure that the metal bracket that covers the earpiece and speaker is properly aligned, and none of the tiny springs on the receiver are bent or improperly seated. They should all evenly be pressed when the bracket is screwed into position.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Thank you for the suggestion. I had to get this back together for the customer, but a weird thing happened. I test it without the bracket for the flex cable installed on the logic board. In a last ditch effort, I cleaned the connector to the logic board and installed the bracket. Then it worked!
Good work, glad you figured it out, cleaning the connector was smart too, pesky iPhones haha.
I will try everything,,earpiece not worked then I changed the screen back to originaland violaearpice now working,, solution is : use only original LCD
댓글 달기
귀하의 답변을 추가하세요
Scott Thompson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 42
전체 시간: 6,817
