주요 콘텐츠로 건너뛰기
2세대 Samsung Gear, Samsung의 Tizen 스마트워치 OS를 실행하는 둥근 스마트워치 입니다. Gear S2는 2015년 10월에 출시되었습니다.
72 질문 전체 보기
Won't charge. Says battery too hot.
I jumped in the pool with my watch on and found out it didn't like it. The screen flickered, but wouldn't come on. Using the tear down video and a 64 piece bit set both from ifixit, I was able to take the watch apart and let it dry out. After that I tried to charge it but got a triangle symbol message with a thermometer in it and it wouldn't charge. I left it off of the charger over night, then put it on the next day and it charged right up and behaved normally! Sadly, when the day was over and I went to charge it back up I got the same warning and it wouldn't charge. I employed the same method as before and it does charge after a few hours off the charger to "cool down"?? Has anyone else had this proiblem? If so, any advise?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
I have Three things to cover
*is the watch waterproof?
  • did you teardown the watch before you jumped into the pool?
  • did you see bubbles in the watch when your in the pool
Hope this was Helpful
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Or probably the battery got shorted and got hot.
댓글 달기
The watch is only water resistant for 1 meter. I thought it was more, but it also can have its water resistance "damaged" if you drop or impact it in any way. I have done both. My bad.
I never tore it apart until after the pool incident.
And I did notice the back of the watch fogged up after I noticed that it stopped working.
But a quick update, it had stopped giving me the error for a while now. Hopefully it continues to charge normally. It does seem to only last 10 hours now when it used to last around 18 hours.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi, i have exactly the same problem. Have you fix it ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
https://www.youtube.com/watch?v=Ocnh-DoN...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Anthony Ramirez 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 18
전체 시간: 1,534
