주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
328 질문 전체 보기
Should the I/O board be replaced?
I have a base model 1.7GHz Core i5 13" MacBook Air and about 4 years ago it suffered some liquid damage. Finally this month when I got the tools I opened it up, cleaning every component of the logic board and the I/O board with 91% isopropyl alcohol. When I checked out the I/O board, I realized there was more corrosion on there than the logic board. In fact, I don't think I found any corrosion on the Logic board. I only found stains on the logic board. (which I cleaned up carefully with a toothbrush)
Do you think there would be a problem with the I/O board, like the onewire circuit? Before I cleaned it, it would blink from a bright green to a dim green light at a slower pace. Now it's not lighting up at all. Well, when I plugged it in after I put the MacBook back together, A showed a bright orange light for less than half a second, and then it shut off.
My guess is the I/O board is fried. There might be something wrong with the logic board, but at this point I am kind of doubting that.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Yes you can do the replacement for I/O board but make sure check other parts too whether they are working fine or not.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
How can I check though? I'm guessing with a multimeter?
And what components should I check?
댓글 달기
귀하의 답변을 추가하세요
Noah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 161
