주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
677 질문 전체 보기
Where can I get parts decently priced?
I've got an iPhone 8 Plus in Red, it's got everything but the screen and battery. The housing is bent and the back is smashed so that needs replacing. I've managed to find all parts I need, except for the camera lens cover, I can find them just not in red! I did find one listing on eBay that has the lens already attached to the glass back, but they won't ship outside of USA which is a problem as i live in NZ..
So is there anywhere else I can get a glass back with lens cover on it, or just the red lens cover? I want to stick with the red just in case i decide to sell it in the future, although I'm planning on using it as my work phone. Or is it possible to just replace the glass lens bit, and i reuse the red frame from this one?
I have mostly been looking on eBay, Aliexpress and TradeMe (nz only equivalent of ebay), but can't find exactly what I'm after.
Any help is greatly appreciated.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
EDIT: I found a 10 pack on Aliexpress
댓글 달기
답변 4개
선택된 답변
I like to order obscure parts from PhoneLCDWholesale. I believe they have what you're looking for here.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Awesome thank you. I will keep them in mind for future use.
댓글 달기
Hi Caitlyn, I recommend that you check out Mobile Defenders, they have high quality parts for a reasonable price, I know they carry camera glas lens. You can find them at: www.mobiledefenders.com
Navigate over to the Apple column and choose iPhone 8 Plus. I hope this helps you find what you are looking for, and have a great day!
~Alec
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I believe the 8 plus with the red housing uses a black lens cover, not red. I’m linking you to a parts manufacturer I know. They usually have what I’m looking for. It’s called Gadgetfix. The first link is to thier 8 plus parts. And the second is to the back glass your looking for.
Link 1 parts
Link 2 Back Glass/Lens
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The lens itself is black yes, but its the red frame part that I'm after.
댓글 달기
Hi Caitlyn, I recommend that you check out CPS : www.cellphonespares.com or www.iphoneLCD.net
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Caitlyn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 137
