Key fob wont turn in my mercedes E 350
I can't turn the key and I Mercedes 2007 E classwhats the problem with this car
좋은 질문입니까?
좋은 질문입니까?
You need to change the battery in the fob . This video may help.
이 답변이 도움이 되었나요?
Not the problem. I changed the battery two times. Still no luck.
Those keys have a copper coil in them that is known to fail. If you have a multimeter check it for continuity. Contacts are one at each end. If no continuity it will need replaced.
Replaced by the dealer?
Or will a commercial key fob be sufficient?
이 답변이 도움이 되었나요?
There are plenty of key replacement businesses who should be able to do a new one and program it to the car. Probably cheaper than dealer prices too.
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 1,000
댓글 1개
I also cant turn my 98 clk 320 key in my ignition . im locked out from even unlocking the igintion lock .. Frustrated and confused... May it be the anti theft. System? If so how do i by pass that
Michael Rodriguez 의
