주요 콘텐츠로 건너뛰기
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
293 질문 전체 보기
98 gmc 4.3l v6 oil pan removal
i have all the bolts that i can see from the bottom of the pan, but the pans still hung up i figured it would drop sorta easy with all the bolts out but there must be some i missed. where do i go from here? take the trans out, the whole motor out?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Tap it gently with a small rubber hammer all around the seam. There may be a gasket that's holding it in place. Use a flathead screwdriver on the end to break the seal loose. You can also use the back of your fist and bump it loose.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Careful wit the screwdriver that you do not bend the surface for the gasket, or you will have a leaky pan.
댓글 달기
귀하의 답변을 추가하세요
steven boomer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,615
