주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
677 질문 전체 보기
Car ran over my iPhone 8+
I accidentally dropped my phone while I was walking and I did not notice it. But after 30 seconds into walking, I noticed my phone wasn't in my pocket so I looked back and seen a car ran over my phone. I went back to pick up my phone but I seen no cracks or marks on the phone but it just won't turn on! Can someone help me!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
And my phone was 80% charged.
댓글 달기
답변 4개
선택된 답변
Try force restarting your device the steps below are as follows to do so:
On an iPhone 8 Plus: Press and quickly release the Volume Up button. Press and quickly release the Volume Down button. Then, press and hold the Side button until you see the Apple logo.
Side button is another word for power button.
Basically press volume up first, then press volume down, then you press and hold power button until you see apple logo like 10-15 seconds.
If that doesn't work then I would assume there is an issue with the hardware inside the phone which then I recommend taking it to a reputable phone repair shop to check what's wrong with the phone. Hopefully just the screen or a loose connection.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Alright thank you but before I try that, I just want to point out that the screen is fully black and also has like green and white lines on the screen, but yeah I'll try your method thank you
Oh, then with that then the screen needs to be replaced.
This happened to an iPhone 6plus I worked on - was amazed that it mostly still functioned with a screen replacement (the screen and the back camera were wrecked but that was about it)
Because the case was so damaged (it had one of those metal ring things on the back) I wound up swapping the logic board into a donor phone and it's still working today
댓글 달기
My iPhone 8 Plus got broken and I didn’t back my pictures up on iCloud or iTunes. Can I still recover them?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Absolutely possible. My iPhone got the same bad luck, you just have to take out the motherboard, then you will probably need to buy a new screen and a new battery as well as the dock. Once you get all of these components you just need to connect them to the motherboard and connect it with the lightning cable to you PC/Mac and you will be able to recover all your data if the motherboard isn’t damaged.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
1) No cracks or marks on the phone after being run over… that’s amazing.
2) If your phone screen is completely dead, first try replacing the screen or battery (or having a phone repair shop do it). When the phone got run over, it’s possible that the touch sensor or other chips or components may have become loose, which can make the phone not work. But even when a phone doesn’t work, it’s still very possible (and likely) that you can recover any photos or other data - as long as the logic board is intact.
3) Need to see it to believe it? Check out: https://flashfixers.com/recover-data-fro...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nano 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 6,409
