주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
931 질문 전체 보기
What is this logic board component?
I have an iPhone 6s Plus that i suspected had a logic board problem because both WiFi and cellular connection didn't, and still doesn't, work. Anyway, I took the logic board out to check it out and discovered that "this" component (blue) was loose. And eventually after I it fell off.
I don't know what this component is called, but since I have a problem with the wireless connection i suspect the component has something to do with this, and in addition also because it is placed right next to the Wi-Fi/Bluetooth antenna cable socket.
So my questions are:
  1. What is the component called?
  2. What does is do?
  3. How can I re-apply it correctly?
Thanks in advance:)
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
가장 유용한 답변
its called utrip_rf its to do with the antennas along the side etc. you wil need a hot air station to put it back on
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Do you know where I can buy that component and how to re-solder it to the logic board?
I have looked around and I have not seen this IC for sale. I didn't do an exhaustive search but it certainly isn't widely available. It is involved in the RF part of the phone so you are probably correct that this is related to your issues.
As for soldering, @tech_ni already mentioned that this requires a hot air station. If you have to ask how to do it, then you aren't really ready to do it on a good phone. Look at the many iPhone repair videos online and observe how they remove IC's. Then practice on dead boards until you can remove IC's with a very high rate of success. Then you can do it on your phone :>).
Soldering with hot air is as much an art as it is a science and you can only learn by "doing" and developing your style that suits your tools and your skills.
의견 추가하세요
I know that without this chip, the Wi-Fi will not work. It is called the UTRIP_RF on ZXW, but I am not sure where to find a replacement besides on a Donor Board.
You will need a hot air station and you will want to ideally pre-heat the board. Remove all of the underfill from around the chip. Add flux and hit it with hot air. I like to use around 360C.
Here are some images of my repair.
Good luck. Hopefully you don’t have to run new traces.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Daniel Kendel 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 97
