주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
671 질문 전체 보기
How can I fix my internal speaker after dropping the iPhone into water
So I dropped my iPhone 8 Plus into the pool whilst playing music and I immediately took it out and the phone turned off, it didnt turn on after the drop. I dried it and took it to a shop to get it cleaned up and they replaced the screen. They also mentioned that the water has damaged the logic board which caused the internal speaker to stop working. I don’t really enjoy calling with speakers on and headphones so is there a way to fix this issue? Should i replace the logic board ? Or is there an alternative way to fix this issue.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If your talking about the ear speaker (the one you use for calls) you can try replacing it, as well as the ribbon cable. But if it is the logic board then the damage is quite extensive and it is beyond basic repair. I’ll attach the parts you need if you want to give it a shot. Good luck.
Ribbon cable
Speaker
Guide
iPhone 8 Plus Front Camera and Sensor Cable 이미지
상품
$29.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
The repair place replaced the ear speaker but nothing happened I couldn’t hear sound coming out from the internal speaker.
If I had to replace the logic board what is the price for the replacement ?
The logic board is the entire phone, and would cost almost as much as buying a new phone. If you replace the logic board then you basically replace the phone. However some specialists can repair the logic board. I recommend looking for one of them
Any suggestions ?
Unbreak ifix will give you a free diagnostic and quote.
https://www.ubreakifix.com/iphone-repair...
댓글 달기
귀하의 답변을 추가하세요
Nhat Cuong Doan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 2,700
