2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
752 질문 전체 보기
Replacing hinge / wifi cable?
I have an early model 2011 Macbook Pro. When I first got it, I was just out of high school and did not know how to take care of nice things. That’s on me.
The hinge is massively broken and when I got it looked at for an assessment, the Apple store told me that the wifi cable that runs up through the monitor was severed at the hinge.
I have to use a Wifi adapter to get Wifi, unless I’m literally sitting right next to the router. It still works great otherwise, and if I could fix it, I would like to.
How would I go about this? I’ve looked at some break downs for the LCD assembly and such, and I’m not 100% which one would actually fix my problem.
점수 0
코멘트 추가
안드로이드 수리 키트
새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
지금 장보기
안드로이드 수리 키트
지금 장보기
1개의 답변
선택된 솔루션
Basically, you’ll need to take the display assembly off to get to the antenna and the hinge units.
Here’s the IFIXIT guide you’ll need to follow: MacBook Pro 13" Unibody Early 2011 Display Replacement. Once you get that far you’ll need to slide off the black clutch cover to expose the antenna unit and hinges. Unscrew it and the hinges. Here’s the antenna assembly MacBook Pro Unibody Airport Antenna and here’s the needed hinges MacBook 13" Unibody Hinge Kit.
점수 1
댓글:
That's exactly what I needed to know! Thanks so much!
의 답변
Just to clarify real quick, I DO NOT need to replace the screen/lcd, just obviously remove it to get to the hinge and airport?
의 답변
Correct! You don't need to replace anything other than the antenna and the hinges. I just did one last week.
의 답변
Thanks so much again! May be a week before I can order the parts, but I will touch base here once I'm done! You gave me exactly what I needed to know.
의 답변
Last question, I promise. If I have to replace the hinge casing, I assume that will be self explanatory once I get to that step?
의 답변
2에 댓글 더 나타내기
코멘트 추가
Add your answer
Laura will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 218
