주요 콘텐츠로 건너뛰기
Repair and support for ceiling-mounted bladed fans.
34 질문 전체 보기
My ceiling fan doesn’t blow down like it’s supposed to
Any ideas as to why my ceiling fan isn’t blowing air like it’s supposed to? We’ve cleaned it, even tried switching the blades around and nothing…
can anyone help…
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 2개
This is an easy answer
Are there directional buttons on the fan’s remote control?
댓글 달기
답변 3개
가장 유용한 답변
@shanersgirl1 there should be a switch on your fan that let’s you reverse it’s turning direction. See if that makes a difference. For as long as the fan moves it should be pushing air, no matter what.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
We tried that, I just looked and it’s down… idk thanks though
댓글 달기
Try changing the capacitor in your fan. Check the old capacitor & replace with ane with similar rating.
For example, If 2.25uF is the calculated safe capacitance that is in the fan; 2.5uF can be used in place of 2.25uF (as it is one of the closest value) can be used, without increase in temperature of the fan motor beyond its failure. The speed of fan will slightly increase with slight increase in temperature of winding. But you may find very less reduction in speed control in lower speeds.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Just below the main stalk of the fan, there should be a switch for changing the direction of spin.
Because the blades are slanted, one direction causes air to move up (for summer), the other direction causes air to move down (for winter).
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Keri Castro Holady 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 8
7일 전: 61
30일 전: 132
전체 시간: 7,584
