주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
모델 A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 또는 3.8 GHz Core i5 또는 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. 시스템이 매우 유사하므로 이전 iMac Intel 27" Retina 5K Display (Late 2014 & 2015) 안내서를 참고하십시오.
202 질문 전체 보기
Does this iMac have a Kensington security slot and what if not?
Do the current iMacs from 2017 have a security slot for Kensington or similar anti-theft solutions? And if not, does the SafeDome solution also work on newer models. The Kensington website only lists models till 2013:
https://www.kensington.com/us/us/v/4514/...
Best, Michael
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
선택된 해법
I went to a discounter and checked out the 27” iMac model. So both 21,5” and 27” have a Kensington lock below the power plug. Obviously Apple doesn’t want to show it – I didn’t find any picture on online showing the slot, so here it is:
Shows Kensington slot on a 27” iMac 5K (2017)
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I stand corrected! The older models this was the case.
의견 추가하세요
가장 유용한 답변
Apple never had a Kensington security slot on the 27” iMac’s. It did have them on the MacBooks but they where dropped quite a few years ago.
The device you’ve linked to mounts to the cable guide hole which is still present on the iMac’s. I do think the current systems hole is the same size but I haven’t measured it. If you really need a tie-down solutions other than a bike cable lock this should work.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Hi Dan, thanks for your answer, but the 21,5” 4K does have a Kensington lock slot, see:
https://www.macworld.com/article/3202397...
Above “Bottom Line” there is a picture with description. But I’m not sure about the 27” model.
I asked Kensington about the SafeDome with 2017 models, they said it probably won’t fit to the current models; I just can’t try.
As you were focused on the 27" models not 21.5" I assumed that was the question. I clarified that in my answer. The 21.5" do as it is looked at as being more likely to sprout legs and run off ;-}
의견 추가하세요
귀하의 답변을 추가하십시오
Michael Gasperl 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 49
전체 시간: 2,584
