Magsafe is orange, but 'battery is not charging'
As you can see, this is my first post so thanks in advance for any advice. Originally, we were getting no light at all on the magsafe adapter when connected to the Air. This power cable works on another Air, but not on this one. And another power cable works on the other Air, but not this one. I replaced the I/O board, but it did not help. I also swapped the battery pack between the Airs and there is no change.
This morning I took my time to inspect the logic board and all of its connections. The logic board looked good, but I realized that I used the original I/O board cable and it had corrosion on the logic board end. I replaced that cable with a new one and cleaned the connector on the logic board end. Now when I plug in the magsafe, I get an orange light as if it’s charging. I’m excited!, but once I boot up the OS says that the ‘battery is not charging’ and ‘power source: power adapter’. The curious thing is that the battery percentage is going down. The screen backlight dims when I remove the magsafe and brightens when I plug it back in. Any suggestions?
좋은 질문 입니까?
