Have a white screen on power up
Moniter was on and all of a sudden went white. Now it is always white no matter what I do. Is it a motherboard issue or something else?
좋은 질문 입니까?
좋은 질문 입니까?
White screens are usually indicative of a bad hard drive or corrupted boot system.
해당 답변은 도움이 되었습니까?
mrbruce300 on your monitor this just means that only your backlight is on. You will have to check the video source and see if it is connected etc. If the monitor does not show a menu etc. on startup when disconnected from a video source you most likely have a bad main board.
These monitor had issues with bad caps, so you will have to take a look at the boards and check for an obvious damage. Post some images of the boards with your question so that we can see what you see. 기존 질문에 이미지 추가하기
Here are the disassembly instructions disassembly.pdf
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 82
